Old 04-17-2016
tbrock's Avatar
tbrock tbrock is offline
Default Q: Idler pulley options? - Series VI
Okay I did a quick search and didn't find a thread on this so here goes. I'm looking to upgrade the pulleys on my car. I run the v-10 water pump pulley, mosaleen system and would like to replace the pulleys with units from thump racing. Just curious with out going out an measuring everything what sizes I will need and how many of each. Is there a kit for a Saleen SC'd car?
2007 Shelby GT, Saleen SC Stage 3 with 3.0 pulley,mosaleen tensioner sys. UCA,LCA,BMR A arm Brace, SVE Dark Stainless 18x10's, Nitto NT05's, MGW Shifter, Pypes LT's with off-road X pipe, Bassani Axle backs, FRP 3.73's,BMR Watts Link, Steeda shaft loop, JLT 110mm CAI, FRP valve Covers, Brenspeed tuned. 12.425@114.63 4800 feet on Nitto 555's. Latest dyno is 492hp/463tq.
Old 04-17-2016
There should only be two idler pulleys you need. The pulley before the PS pulley (90mm) and the pulley in the alternator bracket (76mm). I tried a Thump idler for the alternator bracket pulley and it was too wide and would require clearancing the bracket. I ended up with billet aluminum Metco pullies.
Old 04-17-2016
redflagsc redflagsc is offline
The plastic one w/ Saleen supercharger kit is notorious for having the bearing seize up and snap a belt. Good call to update . Shameless plug to new modders I have a belt, V10 water pump pulley , and Mosaleen system for sale super cheap. All new and never installed . PM me
Old 04-17-2016
tbrock's Avatar
Thanks I completely forgot about the Metco pulleys.
Old 04-18-2016
tbrock's Avatar
Got an email from Rick at Metco and he suggested the 1.5" 90mm idler pulley instead of the 1" (6rib). Can anyone confirm getting ready to place an order.
Old 04-18-2016
Not sure why he wants you to use the wider pulley, but it shouldn't be a problem in that location. It becomes a problem if it's the pulley behind the alternator bracket.
Old 04-18-2016
tbrock's Avatar
Thanks for the info.
Old 04-30-2016
tbrock's Avatar
update on my pulley replacement. The Metco pulleys arrived one 76 and one 90. However since I'm running the Mosaleen system I actually needed two 76mm. So I'll be sending the 90 back and getting another 76. For those running a similar system and a 3.0 pulley /v-10 water pump you cannot run a 106 inch belt. It will not work. 106.5 is the smallest you can use.
Old 04-30-2016
tbrock's Avatar
If someone needs a 106 inch Gates Racing Belt let me know. I'll sell it for $40 shipped saves you a few bucks off of what Rock Auto will charge. Here is the part number K061054RB. PM me if you want it
https://www.rockauto.com/en/moreinfo...860784&jsn=233
Old 05-04-2016
tbrock's Avatar
sent the belt back to rock auto for a refund
