Old 01-08-2021
jrcalvin jrcalvin is offline
Default Saleen Supershaker TMAP Sensor Wiring
A question for Saleen Supershaker owners.
The TMAP sensor is a 4 pin sensor. The Saleen Supershaker Instruction Manual says 5 pin but the TMAP Sensor is actually a 4 pin sensor.
1. The original Supershaker TMAP sensor part number is 2R3A-9F479-AA. Is there a superseded part number if I need to replace the TMAP sensor? Yes, I can also check with the Ford dealer.
2. The 4 pin TMAP sensor utilizes only the two wires, the grey wire and the grey w/red stripe wire in the TMAP sensor female connector/pigtail. The two brown wires in the female connector are not used but are tucked into the plastic convolute.
Question. Which of the 4 pins in the TMAP sensor is the designated pin for the grey wire and which is the designated pin for the grey/red stripe wire?
Orientation should be noted with the TMAP sensor installed on the Supershaker flat plate. For example; aft pin, fwd pin etc.
If I had the original TMAP sensor and female connector I would not need to ask this basic Supershaker wiring question.
Old 01-08-2021
Took a look at mine, 1st pin is grey red, 2nd pin is grey. Going from front of the engine to back.
Old 01-09-2021
Default Supershaker TMAP wiring
Thank you Tbar for taking the time to check out the wiring. I recently acquired a used Supershaker Kit and the Kit had the TMAP sensor installed but did not have the female Connector for the TMAP sensor so the grey and grey/red wires location to the TMAP were an unknown.
Old 01-09-2021
No problem.
