Q: Wiring diagram for the stock SC gauge pod.
I'm having trouble getting my I/C gauge to work. Sensor has been replaced by both variants available. The whole system has been cleaned and flushed so there isn't any sediment blocking it in the reservoir tank. I tested the gauge to see if it worked by quickly touching a ground (as I saw mentioned here) and it did max out for the brief second, so it supposedly works.. Yet I still get no temp readings. Boost gauge works fine though. I know it's simple but does anyone have a wiring diagram for it or a gauge available for sale even?
