Help with Alternator
Car is a 2007 S281 supercharged. Wanted to replace alternator - think I have a diode going bad. Bought a replacement from NAPA, installed it and no charge voltage. Dash says Charging System Malfunction and battery light goes on. Took it back. Bought one from a Ford dealership. Same exact f'ing problem. What the heck gives? Can't be two bad replacement alternators. HELP!!!!!!!!!
No codes to clear. I think the problem is the pulley. The alternator that came with the Saleen appears to be clutchless. The one from Ford has a clutch. Problem is I don't have the tool to swap pulleys. That's the problem with Saleens. Nothing bloody obvious.
Yeah gotta be clutchless
[SIGPIC][/SIGPIC] 13 Boss Laguna Seca #738 05 s281 #1401~ Sold |
05-653 Mineral Grey Brenspeed Stage 3 / Aluminum hood / Shaved antenna / This,that and the other. |
OK, this seems to be a common problem with our cars. What I have discovered when mine first did it was a broken wire in the small wire that connects to the other wires by the front of the passenger side fuel rail.
Next thing that I have found is that when the connector, that has the three or four small holes for the pins, is disconnected from the top of the alternator somehow the connection can be lost and will throw the battery light on the dash and show that the charging system has a fault. Mine has done this a couple of times and especially after disconnecting the alternator when replacing serpentine belts. This was driving me crazy also, and I have seen where others have replaced multiple alternators also in the past trying to get the battery light to go out even after clearing the codes. The best thing to do would be check these simple items first by doing a continuity test on the small wires from the plug end to the wiring harness I have circled in the pic, then making sure that the connection is tight in the top of the alternator and all the pins are making contact as it is not always the alternator itself causing the codes.Recently I had to remove the plug end and adjust the connector plug holes so that they made better contact with the pins. It has not thrown a code since doing this. See attached pic below- |
We suggest factory OEM alt, or Tuff Stuff for the win!
I think I still have my stock alternator from my 06 saleen when I changed it to a chrome one if your interested in it. Not many miles on the alt thats for sure.
How much do you want?
Hey Jason make me an offer I don't plan on getting rich selling it and if I can help some one that's great.
I was just more curious then anything. I usually keep parts like that on hand to help someone. Besides, if you put a price, you'll sell it...!
The alternators in our cars are mounted backwards compared to a stock GT. So when you use a stock alternator with the clutch pulley it free wheels as it is only meant to grab in one direction, the stock direction. You must have a clutchless pulley or you get no juice. Now I have no idea why the stock GT needs a clutch pulley, seems like overkill to me.
Where do you get the tool to remove the clutch pulley from a Ford alternator? I took the Ford one I bought to a Ford dealer and they didn't even have the tool.
05-653 Mineral Grey Brenspeed Stage 3 / Aluminum hood / Shaved antenna / This,that and the other. Last edited by Gray is Grey; 03-07-2013 at 01:02 AM. |
In my particular case, there is no overdrive pulley on the crank
06-1008 S/C Tungsten Gray with Scenic Roof Completely rebuilt from top to bottom |
