1999-2004 Saleen Mustang For the SN-95 New Edge platform. Be sure to specify year, model and equipment if asking for help. |
#51
Here's mine. Quality is OK, not great, but I am picky. Also took about 1 month to have made and ship. As with other aftermarket gauges that I've had the illumination isn't 100% dispersed evenly, but again, I'm picky.
#52
![]() Quote:
![]() ***This is the only current solution for 99-04 Saleen owners that their cluster goes bad. Get a Cobra, Mach 1, or GT cluster and use this overlay plate. With the Cobra cluster, you will at least get the 160mph speedo. Last edited by apicia; 05-31-2010 at 03:16 PM. |
#53
http://www.caribbeancustomdesigns.co...&products_id=1
Here is the link to the options for a plate being made. |
#54
What illumination colors did you choose? How about other options? I want to order one today, but knowing your option choices will help a lot!
#55
Glow looks pretty good. Maybe the SALEEN can light up too.
#56
The white is pretty much white...no metallic.
This is what I ordered: Factory style White backround Dial color - same as illumination illumination color - green backlite SALEEN logos 150mph 8k rpm The do charge an extra $50 for the Saleen logo. Have no idea why...but like you said...there's not many other options out there. |
#57
Yes, the SALEEN does light up.
#58
Did you call or order online? When I put SALEEN into the logo section, the price did not go up in the cart. Maybe they changed their price policy?
I also worry about Dial Color. Choosing "same as illumination" would mean the numbers and lines are green? Yours look black? |
#59
Hehe, I had all the same questions when I bought. The price won't go up in the cart, they will add it. I called after I ordered online, that's how I learned about the $50 cost.
"Same as Illumination" - your right, the numbers and lines will be green but they are very dark so they pretty much look black when the lights are off. |
#60
Here is an email that I received from SIMCO:
Simco Ltd wrote: Hi Tim, We produced the graphics only for the Saleen instrument clusters. What model year is your Saleen? Is the cluster your talking about from the original vehicle or did you purchase it aftermarket? Best Regards, Susan Grove Inside Sales Check us out at: www.SimcoLtd.com ---------------------------------------------------------------------- From: Coderedsaleen Sent: Tuesday, June 01, 2010 10:36 AM To: Simco Ltd Subject: RE: [Simco Website] General Feedback Susan, Thanks for responding back so fast. I have the original gauge overlay but they are on a original 2001 GT cluster. I have the original cluster from the Saleen but it wouldn't work in my car because of the PATS system. I just swapped overlays. I heard that maybe your company has the modules that make the speedometer sweep the 200mph overlay correctly? Any help you may give would be greatly appreciated. Thanks, Tim ---------------------------------------------------------------------- Simco Ltd wrote: Hi Tim, No, we don't have that capability. Putting a Saleen cluster in a GT involves a lot more than just calibrating and programming. You might be able to talk to someone at a Ford dealership that could give some advise. Sorry I couldn't be of more help. Maybe try talking to the guys at www.Redlinegaugeworks.com or www.Classicinstruments.com they both do repair and restoration and they may have some ideas. Best Regards, Susan Grove Inside Sales Last edited by Jim D.; 06-01-2010 at 01:55 PM. Reason: removed email address to prevent possible spamming issues. |
#61
Opps, sorry Jim I should have removed the email addresses.
#62
jut asking has anyone tryed messing with the dm speed cal? or will it work on saleens?
#63
If anyone needs an original cluster send me a pm with year. I have a few from 96-04. For the 99-04 I won't be able to tell you how many miles. Your Ford dealer can reprogram the PATS system to work with your car. If your car is an original Saleen Ford may be able to reprogram your mileage into the new cluter. You will have to confirm with Ford on that one. 99-04 clusters are $375 plus shipping. On the 96-98 I'll have to make sure I still have them. I don't have any spare S351 clusters currently. I have been told the Dallas speed cal won't work for a 200 mph speedo. I have never verified it though. Best bet would be to call them and ask.
96 Saleen S351R #13 97 Saleen S351R #23 vert 99 Saleen S351R #46 (2000 chassis) 95 Saleen S351 #43, SR Spec 99 Saleen S351R #42 (2000 Chassis) 99 Saleen S351R #29 |
#64
Just curious. What kind of mileage do the clusters have for the 99-04?
#65
![]() Quote:
#66
Stupid me, thats what i get for being tired and skimming. My bad guys.
#67
![]() Quote:
#68
If you have a used cluster from a Saleen ford can redo the pats system so it will work in your car. This can be done at the dealership.
#69
![]() Quote:
When Ford gets a brand new cluster, it does not have any calibration flashed on the controller. I am curious if mileage is at zero or there is not data. You would think they can flash the mileage too, if it comes with no mileage data. Ford does not have the Saleen firmware to flash on controller. |
#70
If you order a new cluster from Ford it comes with the milage. You have alot of forms to fill out though. They got tough on this a few years ago. The dealer cannot change the mileage. I'm not sure if you can send your cluster back to Ford and have to changed to reflect your current mileage. That would take alot of checking. I'm sure it could be done if you asked the right person.
#71
![]() Quote:
#72
To do that it would require you to reset the PATs system everytime in the car you installed it in. When you swap the cluster your car won't crank and the pats system reads incorrectly and shuts down the car. I went through that with a theft recovery S281. Most of the clusters I have came from wrecked cars, some of which I had no way to test. It costs $100 for the dealer to rest the PATS system
#73
![]() Quote:
#74
It will but, why turn off your anti theft. Its alot more expensive than going to the dealer and getting it done right. For reseting the mileage stop thinking of shade tree ideas and try to find a real solution. It will save you a ton of headache and money spent on someone elses idea that they can't prove will work. Do some research through Ford. Don't waste your time talking to a dealer. They have nothing to gain by answering your question. You will have to contact a tech representative at Ford who deals with speedometers and calibration or contact this company http://www.instrumentclusters.com/ with proof of your odometer reading and what you need the replacement cluster to read.
96 Saleen S351R #13 97 Saleen S351R #23 vert 99 Saleen S351R #46 (2000 chassis) 95 Saleen S351 #43, SR Spec 99 Saleen S351R #42 (2000 Chassis) 99 Saleen S351R #29 Last edited by S351r; 06-03-2010 at 01:58 PM. |
#75
Saleen had a calibration machine. If I remember correctly it was droped and broken, the cost to repair it was $5000 + if I remember the story correctly.
They have no reason to support these gauges, and the cost of the repair is far greater then the profit that can be made from fixing gauges. They also will never sell you the 200mph gauges. I had a friend who purchased a 2003 Saleen Cobra in Rainbow, it came with the stock cobra gauges. He tried to buy the Saleen gauges forever and they would not sell them to him. |
#76
![]() Quote:
I see your from MA, if you truly need your speedo fixed, contact BBA reman in Taunton, they can fix just about any spedo or electrical item, its gonna cost you big $$$ |
#77
![]() Quote:
You can extract the firmware from the broken machine and let Ford flash the cluster. Firmware people, firmware. Ford can flash it, they just don't have the firmware. |
#78
What about all these companies who make modern gauges for old cars running newer drivetrains with computers? Couldn't they make a unit/module that replaces the stock one, allowing the use of the stock face plate and needle assy?
#79
That would be a good idea. Problem is that Ford has to marry the PCM to the cluster controller to prevent people from changing their cluster. PATS.
#80
I talked to the guys at Electronic Speedometer Service in Washington state and they said for $125 they can transfer the mileage from a GT cluster into the Saleen cluster and they might be able to change the PATS over too included in the $125 price of the mileage swap. If they can change the mileage and Ford can make the PATS system work then putting in a used cluster should work then, right? Not sure if my thinking is right or not but I still dont have the knowledge about this as a few of the other guys on this site so i could be wrong.
http://electronicspeedometerservice.com/ Thats their website. |
#81
Same problem, I'm checking with S351r to see how much he would charge for one of his old clusters. If it's to high I'm going to go with a cobra 160 speed-o with a custom Caribbean Designs overlay on it. Doing the cobra so at least it will not be a GT, Going to go ahead and have the Mach1 style numbers and the saleen logo, figure if its not original...I can change it to at least look completely different instead of looking like a close 2nd. I already have a ton of money in a spare speed-o and saleen overlays. Now I'm just going to weigh the balance of the cost for a used cluster from S351R or a new face kit.
#82
Seems the only solution is to pick a cluster you want (150mph or 160mph) and have Caribbean Customs create a face plate for you. You can custom order the correct Saleen font and black dial ($55 for font and $15 for black dial). Then, have Ford remarry the new cluster to your car.
Since no one is interested in fixing the Saleen device or having someone else fix it. Ridiculous. |
#83
This is not a bash on Caribbean Customs but I have bought alot of stuff from them. I have one of the Saleen white face overlays that I used on another cluster and you can tell that it is not an original overlay. I like all their other stuff but the overlays, I was not impressed. I found an original Saleen cluster and installed that in mine. Yes the speedometer is off, but I have figured out what speed I am going by clocking it with another car. I run 80mph on the gauge but actual is 62mph. I can take a pic of the overlay if you are interested and I probably sell it also. Just my .02 cents worth.
#84
Hey i just found a link about swapping the odometer unit into an autometer cluster.
http://www.99darkgreengt.com/automet...ometertech.htm I bought a Saleen cluster that i want to swap into my GT but the cluster is about 40,000 miles under what my car has. If I'm installing the Saleen gauge cluster into my GT would that work so my mileage would show up correctly? Also i read somewhere that the PATS system is controlled by that unit also but im unsure if that is true. |
#85
I wish they still sold the GT version of the Autometer. You can find 120mph V6 versions of the Autometer gauges around, but 120mph? Simco is sold out of gauges (out of production). Not many choices out there for a Saleen owner whose cluster goes bad.
#86
Do you know if swapping my GT odometer unit into the Saleen cluster would work the same way instread of it going into the autometer cluster? That would save about $150-$200 to ship the two clusters out to have electronic speedo do it. Sorry for so many questions, just trying to figure things out before i take them apart
#87
Here are some pictures of the Caribbean Customs white face gauges:
![]() ![]() ![]() ![]() ![]() Here is a picture of the circuit board, no modules that can be removed : ![]() Back of the gauges: ![]() Last edited by Coderedsaleen; 08-24-2010 at 10:28 PM. |
#88
Based on the autometer instructions, the green circuit board on the back of the gauges is what is taken off and transfered over
#89
I have an old set of gauge overlays from Saleen, I'm going to put them on a GT gauge cluster and try to comp my speed o using my SCT programmer. I know the RPM's will be off by 1000 but it beats nothing. I also have a seat of pro-racer so disabling PATS isn't going to be an issue. I'll try and post what tire size combo does the trick after I get to it.
#90
If you put the GT cluster in it with the Saleen overlay everything else will work as if was in the GT (if the needles are placed back on correctly) except the Speedometer. No matter what you to it with the SCT programmer or tire size it still will not sweep correctly because it is in the programming of the cluster. The speedo needle gauge gets it signal from the speed sensor through the PCM then to chips in the cluster to determine the needle position. What you can do to see how much the cluster is off is to go into the test mode for the cluster, how do you do that? Well first hold down the trip reset as you start the car. Then release after the car is running, this will put it into test mode, pushing the trip reset again it will go through all the things it will test. Some are sensor reading but some useful things for the novice are; bulb test, RPM's, and speed. You will have to play with it to see which one it for the speedometer. Sometime when you go though the whole list it will kick you out and you will have to turn off the car and redo it again.
So the only actual way we can cure this is by getting an actual Saleen cluster and get it reset to the car if you have PATS or install the cluster and disable the PATS. The mileage in the cluster will be the mileage, not sure if the dealer can set it to your original or not. This is first hand experience since I tried to put a Cobra cluster in mine and the mileage was what was on the cluster. Since I still had the PATS I didn't want to disable it because it is easy to disable but a PIA to reactivate it. So I reinstalled the OEM with a real Saleen overlay and all the gauges read correctly except the speedometer. Just some info since this keeps going round and round with no solution. If Dave or Jim could talk to Steve Saleen and find out how the speedometer where manufactured it would clear up all this, but then again this would prevent people from putting OEM Saleen clusters in non actual Saleen's. If the "calibration" machine is broke there is nothing that we can do to get it fixed since this is not a priority of "Saleen" to fix since the cars are six years old or older and are under new management. If Saleen Speedlab was to research what is needed to fix or calibrate new clusters for our years it would be a plus for us, but it cost money and there is not much of a market to offset the cost for such research. There still has to be a way get these fixed though! Just my 2cents. |
#91
Reposted pictures.
#92
![]() Quote:
I don't understand how CC can recreate the Saleen logo without legal reprocussion? Seems like Saleen would be all over that. Then again, I would have thought they would be all over Ebay for alllll of those sellers out there selling fake Saleen badges. Anyway, you should be able to recalibrate the gauge cluster to 200mph with an adjustable VSS module. I installed one ina friend's car who did a T-56 swap (still 150mph speedo though)... all you do is set your perimeters at different speeds and you are good to go. |
#93
![]() No offense, but I would be upset with CC on those. The lettering is off quite a bit, the letters appear to be red, and the "normal" lettering is definitely not profesional. Like I said, no offense or anything, but I would be highly upset with them on that one! |
#94
![]() Quote:
#95
I would imagine it would go to the hands of whoever legally owns the Saleen name now.
#96
http://cgi.ebay.com/ebaymotors/ws/eB...m=270641578075
a 200mph cluster with 80,121 miles. i was considering buying this but after going through this thread it seems a headache to get to work in any 99-04. i know one guy said he got his dyno tuner to program his saleen cluster into his GT. hes on svtperformance if anyones interested in contacting him pm me. he was parting out his GT. |
#97
I purchased a Saleen cluster off ebay recently for my car. I have some questions.
i have a 2002 gt with the stock 150 cluster. I took that out when i purchased an autometer cluster. I took this tiny chip out which contained my miles on my car, 74k and put it in the autometer. when I turned my car on everything worked great lights fuel rpms speed etc. So if i have this saleen cluster can I just take the mileage chip out of the autometer/ stock 150mph cluster( with 74k original miles) and put it in the saleen one? That way it will be the saleen cluster, but my mileage. I can use the green circuit board and such from the white saleen cluster I just want accurate mileage. also i was curious as to how the speedometer would read whether itd be accurate. I dont know much about the PATS system. what I was going to do is put my stock cluster from my GT back into my car take it up to ford and ask if they could change the computer chips, containing the mileage, and possibly activate the pats i know this will cost 100 to 150 or whatever. Im not trying to sabatoge my CPU or make my 74k Mustang appear to have unaccurate mileage. all i want is the saleen cluster installed with the accurate mileage. I dont want to get accused or trying to ruin the data and tamper with the mileage... any ideas... i read through the thread, but im confused as to whether the OP was saying his actual cluster broke, and what he needed or wanted. Would requiring one of these gauge clusters to work require the computer from a saleen, like the one near the passenger seat? |
#98
I wouldn't remove the chip. It should be the one that contains the calibration for the speedo.
The PATS system: You will have to take the car to the dealership to have the PATS reset when you install the cluster. It will still have the VIN in it from the original car and when your PATS system tries to talk to it it will disable the ignition.
#99
What chip are you talking about removing? The pics I posted of the speedo taken apart did not have a chip that you could remove. Unless I missed it.
If it is a authentic Saleen cluster you can take it and your car to the dealer and they can install the cluster then program the PATS to work with your car. That is the thing with the PATS system, you can not just swap clusters at home unless you had the PATS turned off at some point.
My Build: http://saleenforums.soec.org/showthread.php?t=6881 Wind Deflector: http://www.saleenforums.soec.org/showthread.php?t=12930 |
#100
the chip i was talking about is that lil green circuit board held on my two screws in the pictures below. in my autometer instruction it says to take that out of the stock cluster and put into the autometer one which i did and it reads my mileage. the saleen cluster i purchased apparently has 24k on it. my car has 74 original. if i take it to the dealer they cannot do anything about that can they?
my dad also put this in my car when he used to own it. http://www.ravelco.com/ i cannot start my car without this plug inserted into it. i dont know if this being installed has anything to do with my PATS. |
