Q: Codes P0125 and P0443?
Anyone ever had these codes??????
Here you go:
http://www.obd-codes.com/ http://www.obd-codes.com/p0125 http://www.obd-codes.com/p0443
That's good info.. Thank you. Would either of these cause a hesitation whole acceleration? Sometimes in boost it acts like it's missing for a bit then comes back... I changed the plugs and it doesn't fix and it's also not all the time... I can't figure it out, took it to the dealer and they said it was the fuel pump which was a lie, I replaced the fuel pump and the same thing happens...
It happens when your heavy on the pedal in Boost? Happens like split second? Like there is nothing there for a split second?
If you find out let me know because it happened when I had my 2V Saleen Supercharged engine and still does it even after I swapped to the 03 Cobra engine. I think it has something to do with the ECM, I have new everything from plugs to dual fuel pumps. My ECM is the original from my 2V, that is the only common denominator. It doesn't do it all the time either, seems like if I ease into it (While in boost) there is no hesitation but when you jam through the gears you get the hesitation.
Yep, pretty much the same... Doesn't back fire or anything... It's just split seconds of nothing..... Are you getting the same codes?
I am not getting any codes. Just the split second miss.
