Old 05-10-2013
07s281sc's Avatar
07s281sc 07s281sc is offline
Talking Video: Saleen Exhaust w/Magnaflow + Corsa = :)
In my relentless pursuit for exhaust note nirvana, I finished off the Corsa today, so far I am very pleased with the results.
I started off by initially replacing the stock cat for a stainless steel Magnaflow X-pipe with Hi-flow cats. Sound was much better than stock imho however still had some drone issues. Total weight savings was 8lbs vs stock.
For the catback, I had considered the Borlas but wanted the Corsa bc of their noise cancelling feature, can't stand the droning! Last week, I finally came across a nicely used stainless steel Corsa catback for 05-09 GT's, and had the tips cut-off and re-welded inline with my Saleen OEM center exhaust. Sounds MUCH better now and so far no noticeable drone issues inside the cabin. It's quiet at cruise and absolutely rips when you get on it.
Here's an upload of the OEM exhaust-->Magnaflow cats--> Magnaflows + Corsa. Sounds better under load but gives you an idea anyway.
2007 S281sc-437 Rwhp/433 Torque
Saleen SuperShaker w/ 3.6 pulley and custom tune, Magnaflow X pipe w/cats, Corsa Mufflers, BMR Lcas, GT500 fuel pumps, AFCO Heat Exchanger, Chin spoiler, Saleen lower mesh grill, MGW shifter, 2010 Saleen shift knob, UPR Catch Can, UPR Tensioner, V10 Water Pump Pulley, LED Lighting, HIDs
Old 05-10-2013
Nightstalker's Avatar
Nightstalker Nightstalker is offline
http://www.youtube.com/watch?v=OeC-x...ature=youtu.be
Sounds Awesome! The neighbors must love you...
12 Boss 302 -0948 Performance White
12 F150 SVT Raptor SuperCrew Ingot Silver
Old 05-10-2013
DAVESIKE DAVESIKE is offline
sounds kinda tinny..
281 RAD COVER.3.2 PULLEY
ROUSH BELT TENSIONER
3.73 MAX GRIP DIFF,JDM TUNE
GT500 FUEL SYSTEM,KOOKS LONG TUBES
HTO PLUGS,AFCO H/E,MGW SHIFTER
TECHCO INTAKE,ESCORT 9500CI
PIONEER AVH-P8400BH
CARDINALE ENGINEERING FRONT SPLITTER
UPR STRUT CAPS
FORGESTAR F14 MATTE BLACK RIMS
QTP ELECTRIC CUTOUTS
SALEEN FUEL DOOR,CHICANE TOWER BRACE
MESH HOOD INSERTS,281 LOWER MESH GRILLE
FAYS2 WATTS LINK,CAL PONY HOOD STRUTS
WMS STEALTH HOOD PINS
CUSTOM VALVE COVERS,281 COILPACK STICKERS
281 SUPERCHARGER DIPSTICK
Old 05-10-2013
07s281sc's Avatar
Thanks, I think they've gotten kinda used to it over the years. :)
Dave-it's a huge improvement over stock imho. Would love some longtubes but CA emissions is a nightmare.
Old 05-11-2013
I know. The stock is realllly tinny. I put in cutouts. You can adjust your sound. Look into it.
PIONEER AVH-P8400BH
UPR STRUT CAPS
Old 05-11-2013
sidvicious's Avatar
sidvicious sidvicious is offline
That sounds really good. Much deeper than stock. Was it expensive to tie those mufflers into the stock center exhaust?
06-115 / S281 3V / SuperShaker / AirLift / Zenetti Baron forged / JDM / 3M Liquid Copper Wrap
Old 05-11-2013
07s281sc's Avatar
Wasn't that bad at all. About an hour and $100.00 for the install.The Corsas are about 2" larger in diameter but there is enough clearance to cut out the OEM mufflers and reweld inline. I was actually surprised to see the OEM magna mufflers already had holes and were in pretty rough shape. The corsas are stainless so I won't be needing to replace them. Also Did some highway driving today and the cabin noise is virtually gone now. Will try to get a driveby video for comparison.
Old 05-12-2013
Each video the engine sounded gradually better. Still seems real loud, I can't believe you don't hear it in the cabibn, at cuising altitude.
Old 05-12-2013
sidvicious's Avatar
Thanks..Do you have a link to the Corsas? Also, Can you still hear the SuperShaker sucking air at high boost?...I don't wanna drown out that sound
Old 05-13-2013
msb7144's Avatar
msb7144 msb7144 is offline
Wow I like that sound. I HATE the drone of the factory exhaust in the cabin, drives me nuts. I was thinking JBA catted X pipe and new drone free mufflers. Your setup just may do the trick, thanks.
Old 05-13-2013
XxBoostinxX's Avatar
XxBoostinxX XxBoostinxX is offline
Nicely done! I definitely love the sound progression. I have an extra center exhaust laying around I might have to modify :). I need to find the right mufflers first. Can you take a photo of what it looks like underneath? You don't think there is any horsepower lost from loosing the dump in the magnaflow muffler do you? I have always thought you never want to much back pressure or too little.
Sent from my iPhone using Tapatalk
Black - 06-1279 - S281SC
Old 05-13-2013
07s281sc's Avatar
I felt the same way, before the car was just loud with annoying drone. I think the tru-X does help in equalizing the exhaust flow producing a much more refined note. You really don't notice cabin resonance at light cruise but when you step on the throttle it gets loud but in a good way =).
XXBoostinXX, I don't think there is much of a difference losing the dumps. From the exit of the 2.5" Corsa muffler there is only about a 16" section of piping terminating at the tips. Nothing noticeable power wise in the buttt-o-meter either way.
This is my 6th mustang and probably favorite exhaust setup now maybe with one exception being my 96 mustang cobra which had shorty headers, DR Gas Offroad X pipe + borlas. That setup sounded more indy car like at high rpm.
Will get some more pics and drive by vids...
Old 05-13-2013
07s281sc's Avatar
3 drive by clips:
1) Cruise
2) Mid Throttle
3) Full Throttle
Inside cabin just cruising around a bit.
Old 05-13-2013
sidvicious's Avatar
Whoa!!! Sounds incredible ...Thanks for posting vids and pics. I wonder if these Corsa mufflers will sound similar with a JBA catted X? It should sound similar, right?
Old 05-13-2013
07s281sc's Avatar
Np, sound might be similar but I think the Magna tru-x with a full crossover section might equalize the exhaust flow better, just a guess.
Old 05-13-2013
Golf clap to you good sir..... Lol. Awesome work! Thanks for the vids and pics. Now, what corsa mufflers are these.... ;)
Old 05-13-2013
07s281sc's Avatar
Thanks my Saleen brother. These are the Corsa 14311 mufflers and I believe they are listed as their touring model. They are very $$$ new, around $700 but I just saw another nice used set which sold on s197forum.com for $300. They are stainless and should outlast the car.
Old 05-15-2013
1hot281's Avatar
1hot281 1hot281 is offline
SOEC Member (Inactive)
So, with this new exhaust setup, you've eliminated the additional flow of the turn downs in the stock mufflers, and route all the flow through the center exit pipes?
My mechanic told me, "I couldn't fix your brakes, so I made your horn louder..."
Old 05-15-2013
07s281sc's Avatar
Yes all the flow is now through the corsas and out the center exhaust.
Old 05-15-2013
Dude. I take it back. It sounds real good
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
PIONEER AVH-P8400BH
UPR STRUT CAPS
Old 07-02-2013
kenny_k82 kenny_k82 is offline
Account with Invalid Email
Do you have a write-up on how the exhaust was done? I'm considering doing the exact same thing if I can find a shop that is comfortable doing it. Also, do you feel like it takes away from it being an authentic saleen?
Old 07-02-2013
OneQwkStang's Avatar
OneQwkStang OneQwkStang is offline
I would bet you have lost some flow with this set up, maybe even a few hp and some added a little extra boost from the new restrictions. The exits of the Corsa mufflers have been restricted to a much smaller pipe, addition of more bends and out the centre pipes. Would of been a much more efficient system if you cut the centre tips and had them welded in place for looks only, and just ran the Corsa muffler straight dumped like the factory dumps.
Bad idea if your looking for performance
Old 07-03-2013
07s281sc's Avatar
There's only about 24" of piping from the exit of the Corsa mufflers to the Saleen exhaust tips. I sincerely doubt there is any significant loss in hp with this setup but next time I'm on the dyno I will compare the old setup with the new.
Kenny, it's a pretty simple job for any decent muffler shop to handle. IMHO the stock exhaust has noticeable drone doesn't sound nearly as good as the Corsas and you can always weld your stock mufflers back in place if need be.
Old 07-07-2013
FR500GT's Avatar
FR500GT FR500GT is offline
I really want to hear this setup in person
Old 07-07-2013
07s281sc's Avatar
Got any more parts to sell, I could always drive up and you can hear it. Btw-Afco he working out great...
Old 07-07-2013
FR500GT's Avatar
Well I'm parting out my Saleen track build so yeah I have wheels, tires, brakes, exhausts, cage, coilovers, body kit....you name it.
Old 10-08-2013
o2sys o2sys is offline
Which Corsa's are these? Extreme or Sport?
Old 10-08-2013
07s281sc's Avatar
Corsa Sports
Old 10-09-2013
SpecialStang's Avatar
SpecialStang SpecialStang is offline
Sounds awesome 07s281sc!
Here is the dreaded CA emissions question...from my understanding, there is no catted x-pipe that is CA legal; how are you going to get yours smogged and passing the visual?
Old 10-09-2013
KCCHILDS KCCHILDS is offline
Default Nice!
Man that sounds good!
We're not sure if we are keeping the car, but if we do, I have to get away from that raspy oval center exhaust sound. On crank, idle and low rpms, everyone raves about the sound of my car. I have ARH long tubes, catless with h-pipe and stock axle back, and built motor. But if I get above 3k rpms, that higher raspy sound kicks in. I want to do a work around like this, where I keep the center exhaust for looks, but that's it. I may have to copy your set up. Sorry! ;)
Also looking into installing some high flow cats. The exhaust smell is just too much, but we were told that s/c cars ruin cats quickly.
Old 10-13-2013
07s281sc's Avatar
It should pass the sniff test without any problems. I guess magnaflow like many others didn't want to pay the CARB mod tax, so I believe it is currently 49 state legal. If they give me a hard time on the visual then I could always swap the stock cat pipe back in.
KC, I bet they would sound great with Longtubes!
Old 12-16-2014
Dirtbiker Dirtbiker is offline
Bringing back this thread. So I would just take any catback and cut the tips off, and weld it to the pipes going to the center?
Old 12-20-2014
dlford52's Avatar
dlford52 dlford52 is offline
Default Saleen Exhaust- Magnaflow + Corsa = :)
I went with Corsa too. My mufflers are setup the same way Saleen had it... functional centers and dumps. We cut the Corsa tips off and welded dumps in their place, for the centers we punched a hole in the muffler can and welded in the Saleen piping. Suggestions are to measure, measure, measure, cut, measure and weld. I love my new sound and its aggressively LOUD - especially at WOT. I think the longtube Kooks and catted-X may have helped elevate that a bit though. :-)
dlford52 - Saleen Forum(4099153) from Tapatalk.
Mirror Caps, MRT Hood Struts, JLT Catch Can, Kooks LT Headers & Catted X, JLT Series 3 CAI, Bosch Injectors, HTO Plugs, 3.4 Pulley, KB Boost-A-Pump, SCT X3 Tuned by BRENSPEED, Chicane Brace, Pioneer AVH-P8400BH, White Extreme Splitter & Diffuser, MGW Shifter, Raptor Shift Light, 6K HIDs & LEDs, Stealth Bulbs, Steeda X-Brace, Corsa Sport Mufflers, Whiteline Watts Link & Rear Sway Bar, Slotted Rotors Front & Rear, 281 Grille, Dipstick, & Radiator Cover, GT500 Fan
Old 12-21-2014
sidvicious's Avatar
Sounds great.
Old 12-22-2014
dlford52's Avatar
Sounds great.
Thanks. I was real nervous about the change, but I'm quite pleased with the end result
Tags
corsa, exhaust, magnaflow
