S281 Door Decal
I was wondering if someone has the height and a good close up pic of the decal on the doors of a S281. My car had the decals removed and I bought a set, but want to make sure they are the right size. Think mine are 3.5" high.
Thanks! Dave |
Bump, just a measurement will do, I can get a pic later. What is the height of the chevron.
thanks |
That sounds about right, but I got an new set in my house, I'll check it and let you know in a bit
Oh Thanks Seabee! If you have them right in front of you maybe grab a few dimensions if you don't mind
Sorry had to pick up a friend. The height is 3 3/4" on both pieces, from farthest point to farthest point is 10" each. Laid out on the car, altogether about 15" long. What other dimnsions do you need?
this is a terrible pic, but gives you an idea what i'm looking for...lol. The heights of the decal which sounds like you measured at 3 3/4" and the overall length when on the car, from the top left corner to the bottom right corner, straight line length and not on an angle from corner to corner. Is that the 15" you measured?
Thanks again! Dave |
Yea the height is 3 3/4", and the length is about 15"
Anybody know where to pick up a set of replacement graphics but in flat black?
Anyone know the exact specifics for installing them? You peel off the white side and then place the black side down? And then is there another backing you peel off from that? And is it the same as like tint and the windshield decal, where you use soap to line it up right? I'm probobly making it harder than it is but it's different from the other decals I've done.
http://saleenforums.soec.org/showthread.php?t=5422
not a close up but a diffrent view...maybe it will help with your install
One side is paper backed with adesive (side to adhere to the vehicle), the other side has a paper protector to remove after application (the side the faces out).
Try forum user Jess Albright.
So I could just put the decal on like normal, or use soap and water too, and apply it. Then i should be able to pull off another layer of paper? I couldnt seem to get off the other layer, when I was trust trying to figure it out. Ah I will try it tomorrow again.
