Old 11-26-2015
mosaleen's Avatar
mosaleen mosaleen is offline
Default Help: HID headlamp
HI all, I have 2005 Saleen with HID lights, I keep noticing the passanger side light was dimmer. Well finally figured it out, The tornado must have dislodged the
cone that reflects the light back to the mirror, its further away then the drivers side....
Any one know where I could find one?
Thanks Scott
3:73 gears, Watts link Gen II
Old 11-27-2015
One idea: Bake the complete lamp assembly in your oven, separate the outer clear cover from the black housing, adjust your reflector assembly as needed.
Old 11-27-2015
mosaleen's Avatar
Hi Dave, what temp. would you bake it at? Also what do you use to re-seal it back? Thanks Scott
Old 11-28-2015
mikeberg mikeberg is offline
I saw these guys at SEMA. Incase you want/need to swap the bulb.
www.diodedynamics.com/
Old 12-12-2015
I know nothing about this.
mustangforums.com/forum/2005-2009-s197-appearance-section/
